I have recently uninstalled a game I was playing lately and I now I want to install it again. The problem is that I have lost the serial key and now I cannot find it anywhere. Is there a software to retrieve the serial key. I need to know what software it is and where can I get it. Kindly someone let me know of such a software.
Antonio Philippe
Serial key lost – technical support required
Yes you can try to download and install some software that can help you to find lost cd key, serial key or license key.
You can download a software called Magical Jelly Bean Keyfinder its free and has a size of 0.32mb.Magical Jelly Bean keyfinder is so easy to use,after you launched the application it will automatically analyze and show you the keys being written on your registry.Magical Jelly Bean keyfinder is compatible to works with any softwares like, Windows 95, 98,ME,NT4,2000,XP,Server 2003,Vista,Windows 7 Office XP,Office 2003 and Office 2007.
It is a software programs that will allow you to find your Windows product key, serial key and all of the other software that you need to re install on your computer.You can retrieve your serial key by using this application.
