Series of Errors on iOS 6 Update
Since I updated my iPad and iPhones to iOS 6, I had nothing but a series of problems. The applications just keep on crashing. The keyboard will take a while to bring up and message takes too much time to respond. I tried uninstalling the applications and reinstall it back, reset my Apple device but nothing works. Can I just revert it to the old iOS 5?
Best Answer by Inouye Rhonda
Answered By 0 points N/A #125686
You have to update all apps for making those compatible with iOS6. Otherwise, you have to reinstall the previous version.
  • Collect the previous version from Internet.
  • Attach the iPhone with computer by the help of USB and initiate iTunes.
  • Now, start DFU mode.
  • Pick your iPhone model from iTunes, seize downward and initiate restoring.
Visit: http://www.techglobex.net/2012/06/downgrade-from-ios-6-beta-firmware-to.html
Answered By 5 points N/A #197192
Dear Mandy,
At some point the older device can no longer handle the newest software. This was maybe the problem you were experiencing. Luckily, there is a way to downgrade back to iOS 5.
The number requirement in order to make all the processes successful, your device should be jail broken in the past.
Click this link and follow the steps if you have non-A4-powered devices (e.g iPhone 3Gs) or follow the steps here if you have A4-powered devices.
Hope this helps.
Good Luck!
