A serious disk error occurred trying to read/write drive
If this error happened while saving something on to a floppy disk, the disk you are using has a physical problem. Usually when this error happened, there is a bad sector or a bad block on the media you are using. It can sometimes be fixed by using a disk utility application like Norton Disk Doctor.
But if the problem happened while you are running Windows on your computer, there is a serious problem in your hard drive that prevents the system from reading or writing data on the hard drive. Running Windows on a failing hard drive will surely result on the error you received.
Because while Windows is running, it frequently accesses data to and from the hard drive that’s why the hard drive must be healthy and free from physical damage. If this is happening on your system, try checking your computer for any possible errors.
Use a disk utility application to check the system. For a much thorough diagnostic test on your machine, use disk utility applications like PC Tools Performance Toolkit, Norton Utilities, or Norton SystemWorks.
