I received an application error when launching Football Manager 2012. I posted the screenshot below:
A serious error was encountered and the application will close. An error file has been generated in:
JOEY-CB3C3DA99F/C:/Documents and Settings/May/My Documents/Sports Interactive/Football Manager 2009crash
dumps
                                        OK
Serious Error in launching Football Manager 2012
Hi there,
You have Football Manager 2012 launching Problem.
I think you have already uninstalled and reinstall Football Manager 2012. If this doesn’t work then you should try to uninstall ASUS GPI as it is supported that it may conflict with some of the files. If both of the above methods are failed then I am going to mention another solution for you.
Actually it was problem of crash damps. So you have to fix crash damp or FM. You should load steam. After load steam you should go to your game list and select Football Manager 2012 by highlighting. Then you have to right-click and select properties. You should select the local files tab which is located on the far right.
Now click on the Verify integrity of the game cache. Then click on defragment game cache and complete this. Remove/Replace anything you need. Now the files will be replaced and the game will also reinstall.
Hope this solution will be helpful for you.
I can finally play Football Manager 2012. I am very thankful to you JoshMax.Â
I included this application to be excluded and turned on the gaming mode in bitdefender.
I am also grateful to techyv.
