omorkhan
Posted on - 09/18/2011
Hi dear I have serious problem. I faced an error message when I install Software.
How can I solve this error?
I don’t understand what say this error message.
"Setup must stop because the required package Zune didn’t install.
Error code: 0x80070643
https://support.microsoft.com/en-us/help/11696/windows-phone-7
How can I fix this problem from my computer?
Please help me to solve this error. I am waiting for your help.
Thanks
Serious problem in windows setup
This is not an error of the windows installation or an error in your system, but it is the error of your installation setup of windows.
Simply I want to say that if you are installing the program from the compact disk then use a new one because that CD is corrupt one or use DVD for good results.
Another way to solve this issue is that you can first clean your c drive by delete that part and again create it and then install that window in that drive it will also help you to fix a problem.
You are getting this error because a component that is required by Zune software for the installation is missing.
Maybe you did not check the system requirements that Zune require for the installation.
Here are the computer requirements for Zune:
Microsoft Windows 7 (all editions), Windows Vista (all editions), Windows XP with Service Pack 3 (Home, Professional, Tablet PC, or Media Center Edition 2005 with Rollup Update 2), or Mac OS X with Boot Camp running Windows 7 or Windows Vista. Zune software won't work on versions of Windows earlier than Windows XP SP3, any 64-bit version of Windows XP, or any version of Windows Server.
Pentium 500MHz or better
256MB RAM
200MB free hard disk space
CD/DVD-ROM drive
Active internet connection
16-bit sound card
800×600 SVGA resolution
64MB Video card RAM and DirectX 9.0b
USB 1.1 or better
See if your computer has these components.
For additional information about Zune, visit its computer requirements page:
