Brayn
600 points
Posted on - 06/05/2011
I am having two types of problem with my Kingston 16 GB flash drive:
1. When I connect my flash drive to my DELL laptop then its causing my pc to restart immediately.
2. Showing that the folders are empty but there was at least 4 GB data in my flash drive in multiple folders.
I have more then one flash drive and not having such kind problems with them. I can’t try to format the drive because many important documents left there. I don’t want to loose any of that data. Please give me a solution and don’t tell me that it has completely damaged.
chevin7
Serious Trouble with Kingston Flash Drive
Hi Brayn,
This may help to your problem.
Maybe your flash drive is infected with virus. I recommend you to install a USB Disk Security. This provides protection against any malicious programs trying to attack via USB drive. It delivers high level of protection against theft and accidental disclosure of confidential data, and prevents unauthorized persons from stealing your data. This light and easy to use solution is compatible with other antivirus software and doesn't slow down your computer at all.
If your computer restarts automatically once you connect or insert your USB flash drive, try checking your computer using the System File Checker utility. To do this, press the Windows key + R to bring up the “Run” dialog then type without quotes “cmd” then hit Enter. In the command prompt window, type without quotes “sfc /scannow” then hit Enter.
Insert your Windows setup CD or DVD when you are prompted then continue. Wait until the process is complete. When it is finished, close the command prompt then restart the computer. After booting, connect your USB flash drive again then see if it works. If this doesn’t work and the computer still restarts, try checking the contents of the flash drive in Safe Mode.
Restart your computer then press F8 before the Windows logo appears. In “Advanced Boot Options” screen, scroll down and select “Safe Mode” then hit Enter to boot the computer. Once you are logged in, connect your flash drive then try if you can copy all its contents to your hard drive. Once all files are copied, restart your computer and boot normally then format the USB flash drive.
Once the flash drive is formatted, copy the files back to the flash drive.
