Hi expert friends,
At work, I need this in the computer to interact with the client. Therefore, I tried to download the Psi in the computer and I install it without any problem. I am almost to the end of setup, in the end I got an error message. I am confused with the error message, what I have to click now. How will I setup the new account? Help please. Thanks.
Server Authentication
The gmail.com certificate failed the authenticity test.
Reason: The hostname does not match the one the certificate was issued to
Continue Details Cancel
Server Authentication failed using gmail
First Download PSI, then configure it:
Open Psi and Click its symbol in the bottom-left corner, and select Account Setup.
In the Psi: Jabber Accounts window, click Add.
Enter a name for your account in the Name field.
Checkbox next to Register new account should not be selected.
Click Add.
In the ID field, enter full email ID.
If you're a Google Apps user, enter your full email address ( marcus@example.com). Select the Connection tab.
Select all except 'Probe legacy SSL port'
In Host field, enter talk.google.com.
In the Port field, enter 5223 .
In the Encrypt connection drop-down menu, choose Legacy SSL
Select Save
