Server cluster error on analyzing configuration
I get new error messages every time I check into my server clustering. Very often, I get the highlighted error below.
Is there a way to move forward from this error?Â
At first I suggest you to make sure that the Virtual Server Name ‘CLUSTER02’ is unique on the network server. Or, are there any resources that is named ‘SQL Server’ on your Windows cluster? If that has, you may need to rename the related resources to avoid conflicting with SQL Server. After doing this, make a try again to when configuring the software.
Or you can make a try like this- # apt-get install resource-agents-pve
It may work. If this all won;t work, use a trouble shoot to resolve this problem. Here I suggest you to visit the site for a proper process- https://www.microsoft.com/en-US/download/details.aspx?id=53314
Hope this all can help you much to get relief.
For more understanding visit here also- https://support.microsoft.com/en-us/help/281799
