Server down comodo unit cannot sign in
Is the server for the comodo website down again. Comodo unit cannot sign in. I have tried again and again. When will it be back up again so that I can use?
I’m not sure why this problem is happening to you. I already tried visiting Comodo’s official website and I think there’s no problem with their server. The site is up and running as normal. If this is the first time that this happens, try restarting your computer then try it again. See if you can sign in after rebooting the system.
You should also check your computer’s internet connection. Check the internet cable at the back of the CPU if it is properly attached to the port. Or maybe you tried using the program during peak hours where your network is experiencing heavy web traffic. Try it again after a couple of hours or maybe during off-peak hours so the network is not clogged with internet users. You may also try reinstalling the program to have a fresh copy installed on your machine.
Notifications
