Server Error in “/” Application Configuration Error.
I am attempting to install WikkaWiki into my localhost. However I received a configuration error message with the server. How 1 can resolve this?
Server Error in “/” Application.
Answered By 90 points N/A #176137
Hi there Blair Q Johnson,
This problem is can cause because of the NET. Framework is missing on your computer or when the version is not supported. NET. Framework means a program which provides you Programming languages. So in order to overcome the problem what you need to do is
1st go to Microsoft official site
2nd Find the latest update of Net. Framework
3rd download and install it
Your problem will be solved when you done with the installation successfully.
Taylor B Campos,
Thank You
