mercy3
10 points
Posted on - 09/13/2011
Hi
Here is what i have as my problem and i need a quick answer please friends. I use a server on debian linux but when i wanted to start my sa-mp 0.3c server by typing "./samp03svr" "./samp03svr &" and "nohup ./samp03svr &" , i got an error saying: (No such file or directory)
what do you think i should do to proceed?
Error:
/samp03svr  samp03svr &            No such file or directory
Server Error (No such file or directory)
Dear User,
This is very common problem. Please see below and easy way to solve your issue.
First please check that, "samp03svr" this is in the folder.
I think you installed 64 bit version. If so then please install 32 bit library for its RUN. Please enter below command for install 32 bit library.Â
#apt-get install ia32-libs
Please note, you need to login with root user for install or edit any file in Linux. Also if you give permission to any users to administrative work then also can use that user.
Please try this and reply us if you found solution.
Cheers.
