Server Issue: The application was unable to start correctly
Hi everybody,
I Have just compiled Trinity core server.
After that I tried to run my server, but here I got an error via worldserver.exe.
I want to get rid of this problem.
Any tips?
Error:
authserver.exe – Application Error
The application was unable to start correctly(0xc000007b).Click ok to close the application.
Thanks a lot.
Best Answer by Kidd down
Answered By 0 points N/A #153776
Hello Charles,
Let’s check a couple of things first.
1.   .net 3.5 or above should be installed
2.   OpenSSL 64 bit should be provisioned
If above things then in order try installing MySQL5.1 and recompile.
Let me know how it went.
Thanks
Answered By 10 points N/A #153777
Hi Charles,
To compile a Trinity core server properly you will have to use the NET framework 3.5 or higher which you could get via Windows Updates.  And before you compile anything you will need to get the source first and then clone it,
here is a link http://www.ac-web.org/forums/showthread.php?111111-How-to-compile-a-fresh-Trinity-Core
which might be helpful if you want to compile  it again, let me know if it was helpful. Thanks
Kidd down
