Hello experts,
I did some changes to my server and I wasn’t pleased about the result. It was with error and crashes. I tried to recover and repair what I broke and during the recovery this failure message appeared in the end. Can someone help me to run a full recovery without any failure? If this possible please give some tips about servers.
Thanks!
Server recovery complete
Failure
The Server recovery operation failed because the primary volume on the Server could not be written. Click Help for information about fixing the problem. Click Finish to reboot your Server.
Help
Server recovery complete Failure error
Follow the following steps for your server recovery:-
First insert the Server Recovery Disc into a DVD drive in your computer. The server recovery program will automatically start.
Click the next button. Uninstall HP Media Smart Server and Windows Home Server Connector.To do this go to—
Start — Control Panel — Add/Remove Programs. Click on HP MediaSmart Server — remove. Click on Windows Home Server Connector and then click remove.
You will see a Server Recovery dialog box will appear. Now reboot the server for recovery mode. Then click next and follow the instructions that come one after another on each dialog box.
The server will automatically restart as soon as the Server Recovery completes.
Now reinstall the software on your computer that you used to perform the recovery, else you will not be able to use the server. Finally click the finish button on the Server recovery complete dialog box.
