I am running Win XP Operating System and using the built in function to create and store system image on my network store.It was working for me like a charm but now each time I press ‘Back up now’ an error message occurs with ‘Access denied’. I have spent many hours on Google and forums but could find any resolution. I can’t understand this error message. Please help me to resolve the following issue. Thanks.
Services
Windows could not start the Block Level Backup Engine Serviceservice
On Local Computer.
Error 0x80070005: Access is denied.
Services error on Win XP Operating System
Resolution 1:
The first thing you will need to do in order to resolve that issue is to uninstall the Bluetooth driver on your computer:
On your computer, go to start and then type device manager.
After that click on device manager from the search list, and then locate the Bluetooth device.
Right click on the device and then select "Uninstall" to get rid of the currently installed drivers.
Close the device manager.
Resolution 2:
The second approach towards resolving the issue you are getting is as follows:
Go to start, and then run.
Type Services.msc in the dialog box of the properties page of Block Level Backup Service Engine.
Change to Log On tab.
Instead of Log On as Local System Account, change to Log On as [email protected], and then enter the password of admin and then close the properties page.
Restart the Block Level Backup Service Engine.
Tyler
