Services.exe error whenever I open my laptop
Hi
When I try to open my laptp.I always find the following error message (found below). I need to fix this.
Here is the problem file c:windowssystem.exe..
Please help.
Thanks a lot.
Hi
Please help.
Thanks a lot.
Dear Aimee Heart
Services.exe is a part of the Windows OS and it manages the operation of starting and stopping services during the computer startup and shutdown. Â This program is important for a stable and secure running of your computer and shouldn't be terminated or removed. If, as your case, services.exe is giving you errors, this may be because an erroneous application which runs services.exe process. You should uninstall that application and run a registry scan to remove all its corrupted entries and residues. If you have multiple instances of services.exe, this may be a symptom of a virus or Trojan infection. Update your antivirus and run a full scan on your computer in order to get rid of this infection.
Hope this may help you.
Best of luck
