Set up 3G Broadband with Ubuntu 11.10
I just purchased a 3G Broadband from Cricket.
I used it on my Windows PC but I am planning to use it now with Ubuntu 11.10.
But I don’t know much about the setup.
Can someone please help me?
Thank you.
Thank you.
Hello Joshua Moore
You want to install 3G broadband on your ubuntu 11.10 operating system right? Actually, there’s a problem regarding in installation of 3G broadband on this version of operating system it has a bug.
But don't worry in this case ubuntu already fixed the bug. And now i will teach you how to setup and how to fix the bug so that your 3G broadband will work properly.
Heres the steps:
1. Plug in your 3G broadband kit where you want to setup.
2. The auto run will pop-up and follow the setup command for the installation.
3. When its done change the network manager “Ubuntu” status – new – confirmed
4. After you change the network status, if its still not working just unplug it then plug it back.
Hope it really helps you.
Corner stat
