Set up with ISA proxy server and CISCO
The web that we are using is set up with ISA proxy server which is used to check or identify our employees. We are in great need of knowing the web filtering market so that we can know what is competitive and what the prices are. Our interest is in Cisco Iron ports solution. I guess the Cisco is more cheaply compared to the web sense without their gateway and we will have to get it. The Cisco Iron ports seem to have one disadvantage of that you can’t get the information in the internet. Is there anyone with experience of work with Cisco iron port solution if yes how does it work and are there any pros and cons of using it?
One more thing most of our employees use thin clients to connect to the server now how will it recognize the users and may be allow or block the sites that are being accessed? Your suggestions will be highly appreciated.
