Set up MS Office without Overruling the Existing Office 2010
I wonder if I can set up MS Office on my system that is already configured. And then have it on my database which I made in 2003. I do not need to overrule the existing Office 2010. I need advices on how could I make it? Thank you.
Answered By 0 points N/A #95522
                   If you have Ms Office installed on your computer you can still install other version of MS Office. During the installation the setup will ask you if you want to overwrite existing MS Office installed on your computer or to add only without deleting the existing installed. It’s in your control whether you want to open your file to a new version or old version or MS office. But always remember that the file which you created in a newer version cannot be open to a lower version, but the lower version file you created can be open to a new version of MS office. Hope it helps.
