I was attempting to set up xCode 4 with my OS X Lion.
Once I press set up, it just hang and become inaccessible and after a few second it just quit and close the set up. Is there any other way to install xCode?
Please help.
Thank you.
techie 1
Set up xCode 4 with OS X Lion
You must commence to look-up on your Xcode4 and on OS x Lion software that whether the 2 software's are installable in your computer disk drive before your computer has displayed that computer memory is full. When your computer has shown that the memory is filled up.
Then you should uninstall some programs from your computer.You can't set up Xcode with OS(operating system) x Lion.You must find out the problem first to read the monitor page.You may check the security system of your computer.Is there any system disable? You have need to enable them. Please try resetting up Xcode4 osx Lion.
