Setting up an amplifier with my computer
I am trying to fix my personal computer and my amplifier. I have set my amplifier with my computer so that I can access it on the stage. In the amplifier interface, I can only access my music on Drive C: and I could not access any folders except for my music files on Drive C:. I just figured out that the amplifier software has a limitation, and I’m using a Denon AVR 4310.
What I wanted to happen is that, I want everything to run via my personal computer, rather using the amplifier as my controller. I just thought that I need some additional software that can be able to do this for my personal computer. I’m quite confuse in the settings or the source of the amplifier that needs to be use while playing music that will be played on the personal computer streams to the amplifier itself. Any advice will be appreciated and thank you.
