Emaily Rawa
10 points
Posted on - 10/22/2012
Hello experts,
How to configure or set outlook 2010 options calendar? I just got my new Microsoft outlook 2010 installed in my windows 7 operating system and wondering if how it works. Can you teach me how to locate and set the outlook 2010 options calendar? I want to set it on the correct date. Thank you.
Setting Calendar Options in Microsoft Outlook 2010
Hi Emaily,
Here are a few simple steps to get you to the options for your calendar on Microsoft Outlook 2010. Keep in mind as well that changes made here with regard to the time zone will affect the time set on your computer.
Launch Microsoft Outlook. Click on File tab > Click Options > Click Calendar
Here you will find numerous options for your time zone, as well as having a secondary time.
I hope this works out for you.
Kristi
