Quick Time’s java path is on CLASSPATH, I have removed it. But after running the program again nothing happened.
Did I made a mistake removing it or do I change the Variable value?
System Properties
Environment Variables
Edit System Variable
Setting CLASSPATH of java environment variable
Hello Joby,
In case you don't have a Bridge icon on Desktop, you will need to open Win. Exp. and then go to Program files(X86) and then scroll down to the Bridge icon. After that right click and then choose Create Shortcut.
You will have to ensure that Bridge is not running in background, and then reset preferences. And then hold down Ctrl key and click on Bridge Icon. A reset window should come up with 3 options.
Nicke
