Setting drop box stop auto login
I need to be sure if my drop box stop auto login to prevent automatic login when I start up my computer.
I was searching to configuration settings in dropbox, but I didn’t find. Where do I need configure that?
Hello everybody,
We can stop auto login from our drop box. We are storing our files inside our drop box account. We don't want that, everyone who sit in our work desk, have access to our private files. So I can give a solution for this. For Windows, check your Startup program group in your Start Menu or on the Startup tab of MSCONFIG.
for OS X, go to System Preferences > Accounts and remove it from your Login Item
Odom Vemus
You can simply delete you network history to clear your all previous saved passwords and other data you visited over the network.
You can simply choose the password choose only to clear your password related data and then never save the password for the drop box site and you will be able to save your files.
Smith Thompson
Both of your comments are helpful and I would like to thank you, guys. Odom Venus, I am happy with your comment.
You easily showed me that by utilizing a simple step, I would be able to solve my problem.
Superb, really! In your superb process, I was able to configure my Dropbox problem.
I am now free from that error situation.
Thanks again.
