Wayne S Tam
35 points
Posted on - 08/04/2014
Hi There, I need your assistance on setting up my dual display monitor. I want an extended display not an identical one. I have two cables 1 VGA and 1 DVI. My video card is AMD. I am very sure that my CPU capable of having a dual display there might me some configurations that I need to do. Please help.
points
Setting up an extended Display Monitor
It’s quite possible to do with your display. All you have to do is to get another monitor that supports those ports (VGA, DVI).
Connect both monitors to those ports. Your PC should automatically detect the new one. If not, right-click on any blank space on your desktop, select “Screen resolution”. There, from the big box, click “Detect”. This will detect the external monitor and configure to work with that.
Hope you enjoy your display.
