How to set tank lan game? I am usually playing tank game in a single player mode but now that my cousins are presently residing here in our house my dad decided to buy more computer desktop with Windows Xp operating system. Please give me a step by step instruction on the proper set up.
Waiting for your support, thank you.
Setting up LAN with Tank game in Windows XP
To set a LAN game, You have to install the same software and the same version on each computer. You will need a router. Plug the Ethernet cable at the port located into back of the router. Never plug it in the to the "Internet port", this is use for the connection unto the modem. Plug the Ethernet cable on each computers. Make sure that the light in the router turns green corresponding to the number of computer connected in to the router. You can now test the game to know if all the computers can communicate with each other. If it can communicate, you can now play the LAN game, if it cannot, check the wiring if it is properly connected to the ports.
