Setting up office outlook in galaxy ace mobile
I am having up problems setting up Microsoft office outlook in galaxy ace mobile. It cannot connect to server when I enter my email, passwords and stuff. I can't sync anything.
Hi denine punk
GOOD DAY!
I think you are in little bit problem about set up problem of outlook in your galaxy. Don't worry here i am suggest you some informative information i think after following the instruction you will be able to successfully eradicate the problem and will be able to set up outlook in your Galaxy ace.
First I would suggest you to install corresponding link in desktop and synchronize by connection USB and then install deja office to your cell and connect to pc with USB and start sync by tap the synchronization icon in deja office and link will start in pc sync automatically. you need to setup MS outlook in your cell.
GOOD LUCK.
