Setting a Password for my MS Access DB
Good day experts!
I'm planning on setting a password for my MS Access file.
This file serves as my database on one of my program created.
What steps should I do to set a password on my MS Access file?
Answered By 80 points N/A #98960
To create a password for your MS Access files:
  • Close the database first. In case it is a shared file, make sure that all of your users have also closed the file.
  • Make sure to create a backup copy of your database and have it stored in a secure place.
  • Go to File menu and click on Open
  • Click on the arrow to the right of Look In box and select the drive and the folder where the file is located then click on the database’s icon.
  • Click on the arrow to the right of Open button, then click the Open Exclusive option
  • On Tools menu, go to Security and the click on Set Database Password
  • Enter your password
  • Verify and confirm the password
  • Click on OK
Warning:
  • Microsoft Access passwords are not encrypted so to avoid compromising your files’ sensitive data, use the user-level security instead
  • If you lose or forgot your password for your database, it cannot be recovered thus hindering you from opening your files
  • Do not use a password if you will replicate your database because they can’t be synchronized if the password has been defined
  • There is no way for you to create a password for your file if you the user-level security has been defined on your database
To understand creating, changing or removing password on Microsoft Access database better, please go to link.
