Setting a private calendar on MS Outlook
I am using Outlook 2007 with Exchange Server 2003 configured in it. I have created a shared calendar in Outlook and included it as a resource by modifying the Outlook appointment form. The shared calendar should accept all the appointments that are sent out.
The procedure works fine in cases of normal appointments. The problem however arises in cases of private appointments; when a user is sending a private appointment and another user is viewing the shared calendar in the peoples’ calendar.
This person will be able to view the private appointment sent by the first user but without the sender’s name. Due to this issue I am unable to use the private appointment feature.
Can anyone help me resolve this issue?
