Setting up routers security pin
How can I change my routers security pin? I cant connect to my wifi it says that my pin is wrong.Can someone help me ?
To change your router’s password, you will need to access its GUI or Graphic User Interface. The GUI is a webpage where you can configure the settings of your router including your network username and password. Once you have access its GUI, you can try the following:
If you cannot access your router’s Graphic User Interface page because of a forgotten password, it is best that you contact your router support as they will have a way to help you retrieve the right password to access the said page and have your password change afterwards.
