Setting up Skype to check on an elderly parent’s house?
Hi there,
I'd heard about setting up Skype to check on an elderly parents house on a radio show. I'd really like to do that for my parents. How do I set up Skype so that I can check up on them once in a while? They are not good with computers.
Thanks techyv!
Answered By 0 points N/A #149519
It is not necessary to send the data in radio show. All you need is a camera, speakers, and microphone if you want to hear and talk as well. Skype has the option of auto-respond. Therefore, whenever you desire to see that everything is ok, you can simply make a call and Skype will answer automatically.
The procedure is: Go to the option ”Tools” and click on “Options." Then below “Calls” click on “Call settings” and tick the box with the option “ Answer incoming calls automatically." Close the window and you are ready! Every time you will call from now and on you are able to watch your parents.
I hope that I helped you.
