Sumanta61
Posted on - 11/20/2012
I often have to use Tera Term and I need to have several connections in one Window at the same time. Can you please tell me how I can set up a Tera Term tab manager so that I can have multiterminal access via only one Window?
Setting up a teraterm tab manager
Tera Term is a powerful software when used properly. You can configure it TTL script to be able to fetch terminal information from multiple terminals without making too much effort.
If you already have the Tera Term software installed in your computer, then all you have to do is configure its script and make sure that you have Telnet access to other terminals or devices you want to access.
I suggest you follow the procedure on this website that I have read about configuring the script in Tera Term.
Just click this link.
