I am having a little bit problem with setting up Desktop Folder Redirection, what are the settings are required to set up my folder redirection in Windows?
It is really simple to get through it just follow the steps:
Setting Up Desktop Folder Redirection In Windows
To start with reach Administrative Tools, and then look for Active Directory Users and Computers in it.
Go to Domain Properties
Check for Default Domain Policy, it can be found it Group Policies Tab. You have to edit it.
Select the Folder Redirection in Windows Settings
Now, click right on the Desktop Folder, and check for properties
Now you can configure the location of the Desktop folder to whatever you want.
Add whatever user groups you want to add.
Select a group from the domain list in the Security Group Membership box.
Enter the Target Location Folder, and then you have to use an UNC(Universal Naming Convention) path to whatever location. This is where your Desktop folder be situated.
Apply the settings and then log off.
Log on and you are done.
Do check the location!
