Setting Up Samsung Galaxy S5 Account In My Mobile.
Hi, I bought a Galaxy S5 phone and needed to setup an account. How can I Samsung Galaxy s5 account in this new mobile? Can you give me easier steps?
Follow these easy steps:
There, you have set up a new account on your phone. If you are starting the phone for the first time, a screen will ask you to set the account in the beginning.
The Samsung Galaxy S5 is a discontinued 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was unveiled to the public on February 2014 and released on April 2014 measuring 142 x 72.5 x 8.1 millimeters and weighing 145 grams. It uses micro-SIM card and built with plastic body.
It is IP67 dust and water resistant certified (up to one (1) meter for thirty (30) minutes). It has Super AMOLED capacitive touchscreen display with 16M colors at 1080 x 1920 pixels screen resolution protected with Corning Gorilla Glass 3.
It ships with Android 4.4.2 KitKat upgradable to Android 6.0 Marshmallow with TouchWiz UI powered by 28 nm Qualcomm MSM8974AC Snapdragon 801 chipset, 2.5 GHz Quad-Core Krait 400 processor, and Adreno 330 GPU. It supports microSD expandable up to 256 GB. It runs on 2 GB RAM with internal storage available in 16 GB and 32 GB capacities.
The primary camera supports 16 megapixels with f/2.2, 31mm (standard), 1/2.6″, 1.12µm, and PDAF featuring LED flash, panorama, and HDR and can record video in 2160p at 30 fps, 1080p at 60 fps, and 720p at 120 fps featuring HDR and dual-video rec. The secondary camera supports 2 megapixels with f/2.4 and 22mm (wide) featuring dual video call and can record video in 1080p at 30 fps.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, and hotspot support; Bluetooth 4.0 with A2DP, EDR, LE, and aptX support; GPS with A-GPS, GLONASS, and BDS support; NFC; infrared; and microUSB 3.0 with MHL 2.1 TV-out and USB Host support. It doesn’t have FM radio.
It has built-in front-mounted fingerprint, accelerometer, gyro, proximity, compass, barometer, gesture, and heart rate sensors with ANT+, S-Voice natural language commands and dictation, and air gestures. It runs on removable Li-Ion 2800 mAh battery with standby time up to 390 hours and talk time up to 21 hours. It supports Qi/PMA wireless charging. It is available in Charcoal Black, Copper Gold, Electric Blue, and Shimmery White colors.
