Setting Up Speech Recognition Windows 7 64 Bit
What is the use of speech recognition Windows 7? How to set up speech recognition feature in Windows 7? What are the devices required for setting up this feature?
The speech recognition feature allows the user to input data into a document using speech rather than a keyboard or a mouse. You can also control, select or de-select software. You can also use the feature to authenticate the identity of the speaker as a security measure. To use this feature, you need a microphone or a headset attached to your computer. To set it up,
1. Choose start, control panel and then Ease of access
2. Then choose Start speech recognition
3. Click next to continue
4. Choose the microphone that you are using and then click next.
5. It will ask you to read a sample sentence, read it and when you are finished click Next and Click Next again
6. By default, Speech recognition will run at Startup.
If you are referring to WSR or Windows Speech Recognition, it is a speech recognition component for Windows Vista developed by Microsoft. It allows the use of voice commands to control the desktop interface; dictate text in electronic documents, email, and forms; perform keyboard shortcuts; navigate websites; operate the mouse; and create macros to perform additional tasks. It is a locally-processed speech recognition platform.
It doesn’t depend its accuracy, dictation, and or recognition services on cloud computing. Instead, it adapts based on user’s continued input, speech samples, grammar, vocabulary, and training sessions. For dictation, it has a personal dictionary that allows users to include or exclude words or expressions as well as to optionally record pronunciations to increase recognition accuracy.
The Windows Speech Recognition was developed to be an integrated component of Microsoft Windows Vista because previous versions of the Microsoft Windows operating system only included support for speech recognition capabilities that were limited to individual programs like the Windows Media Player. Windows Speech Recognition relies on the Speech API developed by Microsoft and third-party software should support the Text Services Framework.
Windows Speech Recognition is also included in Windows 7, Windows 8.x, and Windows 10.
