Setting up Ustream on your laptop
How can I set up Ustream on my laptop?
What is the step by step procedure and the things that I need?
In the website  click sign up on the right hand corner of the front page.
Then fill up the blanks that are required after filling up check the "Terms and Services" box and click "Create my Account" when you are finished log in to the website, the log in form is located on the right hand corner of the website this will bring you to your dashboard. then there are several functions on the dashboard that you might need.Â
llÂ
Hi, Kristan.
In order to use Ustream on your laptop, you must first sign up into the website.
Please follow these simple steps to create an account at Ustream.
Thanks and regards,
Skarbos Jay.
Hello Lai,
I think you want to install Ustream on your laptop so that you can make new broadcast able video any time.
Than just download the setup file from this link:
I think you already know how to create an account.
So I don’t want to repeat that. I hope you already tried out to make a show.
The desktop software is same as the website. If that is not a registered software than you cannot broadcast from here.
I am telling you some steps so that you can find it easy. Select create new show.
Then fill out the form and click on ok. Now you can record whatever you want. Now your show is ready.
Thank you,
 Riley Weaver.
Hello Kristran,
To set up Ustream on your Laptop, you need to follow the steps given below:
1- On the upper right corner of the Ustream website. Click on Sign Up.
2- A registration form will appear. Please fill it with your information and hit the Create Account button.
3- Now to see your dashboard, click on your username you provided earlier.
4- Go to Account Settings to personalize it with pictures and bio data.
5- In your dashboard you will find a button Create a show, click it.
6- You will see the box on your screen, Type the appropriate information to setup a show.
7- You will be provided with a link. Save the link to access it.
8- Now setup your laptop and go to Ustream site, Click the button Broadcast.
9- Now finally hit the start button to start your broadcast.
That will be it.
Thanks
