Setting WiFi passwords saved in window 7
How to get stored WLAN "passwords" from windows 7?,
How do I back up and restore (in case of reinstalling the wlan adapter driver) or transfer (in case of switching wlan adapters or laptops) WLAN profiles?
Hey Carolyn1830
Good Luck!!
Hi Carolyn,
You will get stored WLAN "passwords" from windows 7 by taking following step:
First click on the taskbar on the WiFi Network Icon.
Second please right button click on your wireless network connection and click the “Properties”.
Third click on “Security” tab in the Wireless Network Properties.
Then you will see the Network Security Key that you entered during setup of WiFi Network.
Fourth But it will not be readable format. Then check the box “Show Characters” to make the password readable.
To back up and restore your WLAN profile takes following step:
