Hi i do not have a router.
But i want to use WiFi on my mobile from my laptop.
I have heard of software's that can actually turn your laptop into a wireless network enabling design.
Which are the software's for doing so and how they work?
Setting up an wireless network using your laptop wifi
Hello Joseph.
While there are ways to transform your laptop or desktop with a wireless connection into a router, the procedures are usually not for the common user.
Now there is a software application that only takes minutes and few clicks to turn your Windows 7 WiFi – enable laptop into a wireless router.
The software is called Connectify and you can find out more about it here:
Connectify works by taking advantage of Windows 7's native Virtual WiFi Technology.
This is the technology that makes it possible for Windows 7 to share it's WiFi connection with other WiFi devices.
This also means Connectify will not work on Windows Vista and older Windows versions.
