Settings for Block pop-up Windows
I’m using a Mozilla Firefox browser and it always blocks pop-up windows. Where I can find the settings on how to allow pop-up windows in my browser?
You may want to enable your pop ups but my advice to you is don't allow all popups when the browser asks you to do so. Sometimes they may contain links to spyware.
To allow pop ups in Mozilla Firefox these are the things that you have to do:
Web browsers not just Mozilla Firefox use an option to disallow displaying of pop-ups or the ability of a web page to open another tab and often display advertisements. It is a good feature of a web browser to avoid seeing annoying web pages that will only sell you something or will ask you to answer some survey.
But sometimes there are good pop-ups that are required to complete a transaction. If your web browser blocks all pop-ups, a transaction that requires opening of another tab may not be completed. There are 2 ways you can allow showing of pop-ups. First is to disable the option allowing all pop-ups from different websites to be shown and second is to add exceptions.
The first option is not recommended because it’ll open your web browser to a whole bunch of different pop-ups from all websites. The second option is the one recommended. If you require pop-ups to be displayed for a particular website, you can add it to the exceptions list. On your Mozilla Firefox, click Tools, and then Options.
Select Content tab then make sure “Block pop-up windows” is checked. Click Exceptions button. See image.
On the next window, enter the address or the URL of the website you want to be exempted the click Allow. When you are finished, click Close. See image.
And that’s it. After that, whenever you open that website on your web browser it will open all pop-ups.
