Setup A Remote Access Server 2012 In Windows
I want to setup a Remote access Server 2012 in Windows. How can I fix the problem? Is there any simple way to do this?
You will have to follow the below-mentioned steps for doing the same:
For installing the Remote Access role, go the Server Manager, and then click Manage, in that click on the Add Roles and Features and then click next
Now click on the Remote Access role and then click next
Select the option of Direct Access and VPN, then select next, and install
2. Setup the Routing and Remote Access
3. Now finally, allow the users to connect to the server
You have an option to enable VPN for the individual users. If you want, you can enable it from Active Directory.
