Setup cannot be completed while installing the features
When installing SCOM setup fails during the data warehouse step and the setup log file contains an error while attempting to open or create the physical file ‘E:SystemCenterData.mdf’. Any solution for this error ?
Thank you !
Please review the installation result. You can repair or add features by restarting Setup.
Initial configuration
Operational database configuration
The feature installation was successfully rolled back
Management server
Data warehouse configuration
Data warehouse configuration failed to install
Operations console
Web console
Reporting
