I have CCTV cameras installed in my shop. I usually view it on my mobile device using SuperCam Application. Earlier I had Netgear DGN1000 Router CCTV cameras were setup accurately on it. Now I upgraded to D-Link DSL-2750u Router. Now I want to set the Cameras over my new Router. I am unable to set it up using the same procedure as I did on my previous Router. Need Help Urgently. Publish the Solution as soon as possible.
Setup CCTV Cameras using DVR over Wi-Fi on D-Link DSL-2750u?
First, note the static IP address of your device. Log in to your router using the internal IP address of your router, your username, and your password. When you log in, you should see the administrator console. Select the “Advanced” tab and choose “Port Forwarding” in the left side panel menu. Then select “Add.” Complete each field with the device information. Your phone application should provide easy guided setup for other networking tasks. If you still encounter difficulties, I suggest experimenting with other CCTV phone applications or perhaps checking the D-Link website for applications known to be compatible.
