Setup of DNS server Active Directory Domain
What will I do first if I wanted to setup a DNS server Active Directory domain, should I install the DNS service first and name the zone ‘name.org’? Can I use the ‘name.org’ in the AD domain?
You can install and configure DNS before installing Active Directory (AD), or let the AD installation Wizard itself install it on your server.
It is preferable to use DNS zone and Active Directory name same, so use can use ‘name.org’ in AD domain.
·        Domain controller will neither create nor join Active Directory domain without a valid DNS name.
·        Active Directory can be installed with the dcpromo command
Hellow Olivia Green!!
I am telling you how to setup DNS server .
To configure DNS server you have to follow the procedure:
If you have an Active Directory Domain ,you should configure the DNS Server as follows:
Regards
Shifflet Laurel
