imrankhan
Posted on - 09/18/2011
Hi I faced an error problem when I install SMS Advanced Client software. Always show this error message. I don’t understand why I see this error message.
Setup was unable to compile the file SmsClient.mof
The error code is 8004100E
Anybody knows how I can fix this error problem. Please help me to solve this problem. I am waiting. Thanks
Setup error in SMS Advanced Client
Hello Imran,
Are you installing it for the first time or have you already tried istalling it before with a different password? Also are you trying to install it through a different network access account? If yes than that can be the reason of your problem.
Well I would suggest you to use Advanced Client and Management Point Cleaner to sort out this problem. Just remove SMS Advanced Client Software with Advanced Client and Management Point Cleaner and then reinstall it and that's it you're done. Once you do that you'll be able to use it perfectly without any issue. Good Luck,
Thanks!!
