Setup Error while installing Nitro PDF Reader
I am running Windows Vista Home Premium on my Toshiba A200 laptop. I am trying to install Nitro PDF Reader but I am receiving a setup error 0x80070002. How can I fix it?
Hello.
This is happen to your Windows problem and the install program you selected would not register.
Reader might loss the existing file to install. You have to install the program in legal notice. The option would cause for active reader existing file. You may choice one application for running.
Related Windows upgrade sites. You may upgrade the levels of Vista program. Check the space of disk to saving. All the way of you means clear to install. Exceeding files on your PC created to problem by operating. Whether you remove same soft, you may success in installing your own. You may get the solution.
You need to check the following things to make sure that you are using a valid copy of your program.
I am sure that after you have make these changes you will be able to solve your problem.
Nitro PDF Reader supports Microsoft Windows Vista but you have to install Microsoft .NET Framework 2.0 or higher to make it work. Microsoft .NET Framework is required to install Nitro PDF Reader on any of the supported operating systems. Nitro PDF Reader supports Windows Vista, Windows 7, Windows 8.x, and Windows 10 including Windows Server 2008, Windows Server 2008 R2, and Windows Server 2012 R2.
It requires 1 GHz or faster processor, 512 MB RAM, 1024 x 768 minimum screen resolution, 335 MB free space, and Microsoft .NET Framework 2.0 or higher. Since .NET Framework is required, you can download Microsoft .NET Framework 3.5 Service Pack 1. Microsoft .NET Framework 3.5 Service Pack 1 includes .NET Framework 2.0 Service Pack 2 and .NET Framework 3.0 Service Pack 2.
If the problem continues and you still can’t install Nitro PDF Reader, try installing Foxit Reader instead.
