Setup failed while installing sub-component Microsoft Active Directory
On the install and uninstall process of Exchange Server, I got the following error.
Setup failed while installing sub-component Microsoft Active Directory schema update with error code 0xC1037986(please consult the installation logs for a detailed description). You may cancel the installation or try the failed step again.”
Do you know what this is?
I need help.
