Setup Obiee 11g Ibots
I want to setup obiee 11g ibots. Me being the end user trying to create the same but this is not working at all. How can I do the same please help?
The iBots are received by the end user and the end-user login is integrated with OBIEE 11g from Oracle. The limitation of this configuration is that the end user can not create iBots and send them to another user. Only the Weblogic administrator can connect directly to OBIEE and create the iBots. Configure the SMTP setting in OBIEE Enterprise Manager. Log in to Enterprise Manager.
Under Business Intelligence, click Core Application. Then click the Deployment subtab, and then click Email. Configure the SMTP server correctly. Restart the server. Log in to Oracle as the end user of BI. You will see OBIEE at the bottom of the screen because your ID has been integrated with OBIEE.
Your user is allowed to connect to OBIEE. Click on my account. Click on the shipping option. You can have different options. Then create a new device. And the last step is to login as weblogic user and then you can setup your ibots.
Notifications
