Can someone please help me figure out these problems I am experiencing since I upgraded to IOS version 5.0.1? First, the battery runs out very fast than before and second the screen keeps shaking when y
Lee Seen
Shaken screen and battery runs out fast in IOS 5.0.1
Well, did you check the system requirements of the new IOS version that you just upgraded to, for the problem may be as a result of the new version demanding a little bit more compared to the older version. The new version may be having a lot of applications executing on it which are using a lot of battery power and thus making it to run out so fast. You will therefore need to check if there are applications that you can disable so that they do not finish the battery charge.
The reason for the shaking of the screen may be because of the device not having enough memory to support the new IOS version that you just upgraded to, and for that reason you may want to upgrade the device memory.
-Lee Seen
Those changes that are happening on your iOS device are probably caused by your new operating system, iOS 5.0.1. The battery dies fast because of the new operating schemes brought by the new operating system. It is probably running more processes than the previous version. Also, make sure your device is compatible with the new iOS 5.0.1 mobile operating system.
Not because it is an iOS device you can upgrade it to any version you like. Every version of the iOS mobile operating system has a target range of supported devices and these devices are the only ones that should be allowed to upgrade to this version. Any devices outside the range should not be allowed to upgrade to this version because it will cause problems to the device.
