Share internet from my desktop to iPHONE
Asked By 5 points N/A Posted on -
I want to download some APP's to my iPHONE and i dont have a 3G connection on my phone. I want a way to get the internet from my desktop
We dont have a Wifi available so its a wired LAN environment
Windows 7 OS
Answered By points N/A #177990
You don’t need to use any LAN connection.
But be careful, this technique is not available for iOS 7, highest iOS 6 supported
You can use your iPhone as modem with fast performance. Just simply connect your iPhone to your PC via USB. Then, follow the following steps:
1. From your iPhone, click the “Settings” icon on the home screen.
2. Go to General >> Network >> Internet Tethering. Turn it on.
3. Connect your iPhone to your PC via USB.
4. From the bottom-right side, click on the “Network” button.
5. Go to Network and Sharing Center >> Connect to a network.
6. Click on your iPhone and select “OK”.
Now your iPhone will be used as a USB modem.
For further technique, you can visit this page.
