Share with me some html5 report sample. I have to make my documentation about my html5 developed webpage project; documentation will serve as a user manual, a guide and information about your webpage system. How the user would be able to upload, download, put images and texts to the website. Would you love to show me some html5 report sample?
Waiting for your support.
Halo Shannon Larry
You have requested to share some HTML report sample. I am giving you some link of HTML report sample after research. You also can get here how the user will able to upload, download,put images and text to the website. I think you will satisfy ! Lets see…..
HTML report sample (1)
HTML report sample (2)
50 amazing example
REGARDS
Washington Michael
Dear shannon Larry,
You can upload and download images to webpage using source code of HTML5 with JavaScript in which you can also crop your images as well. I want to tell you can write that source code in php and can edit and execute in Dreamweaver as well. You can execute that coding and perform your task easily. The best communities regarding coding are github and infragistics and paramount coders.
Hopefully this can help you better Thanks
Raun Nelson
