Share with me ticket invoices examples?
Hi all,
I am planning to start my limited company and for the billing purpose I need to collect few ticket invoices examples. Please share with me some invoice template made in ms word or ms excel.
Also, please note that template should include fields like company name, company address, company telephone number, company email id, date, payment terms and condition, invoice number, amount, total, etc.
Best Answer by Steele Ney
Answered By 0 points N/A #167873
You may take a look for the example below:
encode INVOICE at the top
You can customize your invoice ticket like this by downloading installing templates in MS Word. By doing this, you can encode INVOICE at the top: Please refer to the given example. If the installed template have written another's company then you can edit this by simply changing it in your company's name and other necessary and miscellaneous information in your invoice ticket.
Then save it to your computer's drive, Anytime, you need this just open the file and print it. Or, I'll give you an easier option, you can buy pre-made invoice tickets in a book store or anywhere you know. You just this to fill up each every time you need them in your business.
Thanks,
Steele Ney
Answered By 0 points N/A #167874
Hi Mcleod,
See the below invoice. You can easily create invoice by yourself with the required fields. There is some free software available such as Express Invoice which are very handy if you don't want to pay for this. Download and install this software, give your company information, customize the fields and view and print the invoice. It's that simple.
